Brief Description: Began Chpt 12...Installing fairings
I took the tail feathers off the aft fuselage and began work on the bottom rudder fairing. I cut the fairing with a cutting wheel on the dremel tool. Just follow the scribed line and trim to fit. Measured and drilled holes for #6 screws.
