Attached elevators and trim tab to HS and set in trailing position IOT drill holes in the elevator horns. Per the manual I used the drill press with a file to smooth the E Drill guide. I did both holes in each horn per the instructions with no issue. I did notice looking down the trailing edge of both elevators and trim tab that the trailing edge was not totally straight once all pieces were put together. It appeared to be about 1/8 of an inch off true in certain spots. Not much i can do about it at this point. Will have to see if it flys true before making any adjustments.
