Brief Description: Riveted ribs and trim access panels in place
Finished back riveting ribs to upper and lower skins. There is one rivet on the E-1008B ribs that the short back rivet set wouldn't reach and I didn't have the 12" one that Cleavelend sells so I used the 3x gun with the tungsten bucking bar. Mason worked the gun while I held the bar. It seemed to work fine but was a little slower. Also riveted trim access panel pieces into place. I ended up using the squeezer for most rivets but I think it would've been easier to back rivet the reinforcement doubler (E-1410) in place then do the brace (E-1411) with the nutplates. The instructions were a little unclear to me on the order (except for the first two that need to be done before the brace is put in). I used two different yokes...the 4" one would reach the interior rivets and the 1.5" could fit in the access hole and do all of the ones in that area.
