MIKE'S WEB SITE
Date:  6-30-2020
Manual Reference:  9-07
Brief Description:  Trim tab hinge fabrication
Finished clecoing bottom skins, spars, ribs and trim motor housing together. Had to debur the edges of the trim tab motor housing pieces. The dremel with the 3M scotchbrite wheel i modified and attached to the mandrel worked well in the tight spaces. I attached the forward part of trim tab hinge to rear spar (underneath top flange of rear spar) with 1 cleco and cleco clamps then match drilled the #40 holes and clecoed as I went along. I drew a line along the hinge once i had it parallel to the flange so it would help me keep it aligned as I went along. Once that was done I marked the end and trimmed the excess with the band saw. Did the same thing for the aft hinge.
Dremel w/modified 3M pad
Forward trim tab hinge
Aft trim tab hinge
Aft trim tab hinge
