Today I installed the aileron brackets, as on the left wing I made first an alu dummy to get the bend right. Next pressed the bearing in with my highly sophisticated press setup (two drive nuts and a vice). And for the outer aileron bracket I had to back it up with two washers and filled it in with techno glue to get the right height, unfortunately the outer mountings lugs on both the ailerons are not the same!
