Brief Description: Installed the Flap and Wing Tip Vent
Cut the slot for the flap connection rod into the fuse and tested it with the flap motor, worked. Also found on this wing the flap brackets had to be slightly bend to fit! Before I forget I installed the wing tip vent check valve; not a big deal.
