Brief Description: Aileron Linkage and more Filling
To trail fit the aileron linkage I had to drill the whole into the trailing edge of the wing. Taking the manual picture, the aileron pushrod was mounted onto the inside of the aileron bracket. Therefore the whole should be more to the right. Wrong, the gap at the aileron attach point was too small to fit the eye and the nut. The whole had to be closed up again and redrilled 10mm to the left. Not a big deal took just time. Now the linkage connected to the crank I was able to operate the aileron and test a free movement. More filling was required around the landing light mounting. Filled and sanded, usual task.
