Brief Description: Test Fit of Flap and Aileron and Cutting Trailing
After squaring all the edges of the flap and aileron I test fit them onto the wing. The result was very satisfactory as it turned out the gap was now exact 3mm and square. As final work on the wing was cutting the trailing edge to much the flap and the wingtip onto one line, which required a max cut of2.5mm on the flap trailing edge where it meets the aileron to be in line with the wingtip.
