Brief Description: Control Mixer trail and Sanding
To determine the location for the aileron control tube movement I had to install the control mixer. Unfortunately I had first to insert the bronze bushing which would be a lot easier when the spar box was still out of the airplane, as it had to be filed down as well. Anyway I found that the cut out could be a lot smaller as the movement is not that great, which I will test at the next full wing assembly. Further preparation of the control surfaces which was fine sanding the lot.
