During waiting for the AOI bolt preparation, I installed the pedal support frame. This was a quit an exercise to get it square, because the bulkhead is completely out in all dimensions15mm horizontally and 9mm on the centre line! I had to build a frame onto the fire wall to have it as reverence. As next I drilled the first two crucial bolt holes for the engine mount; got it very level only 0.03deg off!
