The big question today was if the release wax was enough or not? But I was positively surprised as only a light bump from inside the fuse popped the frame of the fuse with a perfect edge. A light sand to clean the fibreglass of and a refit to the fuse showed how good it came. This method is definitely better as the one used before with the fiberglass skin. The next step will be to put a fine layer of filler on and sand all back and even with the fuse.
