Michaels Web Site
Date: 8-5-2012
Number of Hours: 5.00
Manual Reference: 41
Brief Description: Canopy Hinge Install
The install of the hinges were not that easy as I thought, at least for me. The reasons why, was that the front bulkhead was 5mm off square but also the canopy cut-out is not symmetrically left to right, again 5mm out. This resulted that I had to underlay 10mm on one side, where the right hand side was ok to make both hinges the same, but the right should be 10mm further to the front, with other words the bulkhead was 10mm too far back. The result was, on the right side the hinge would not match the frame to attach, 10mm offset, no way to rectify without an ugly fix! Very complicated! The solution is, the mounting is right only the hinges need to be made with a 10mm smaller radius! Again a lot of extra work but I like to have it right.
Dash-board Installed
