Brief Description: Luggage Support and Rudder Control
Today I finished the luggage middle support angle as a removable support, which was a bracket glassed to the side wall and the beam secured with a bolt. Next was the rudder control as I haven't finished this yet. As Gordon P already noticed I missed the nut inside the rudder as well! Dennis has confirmed to drill an access hole is the right way to go, which I did. Also bent a washer to support the nut inside, had to make a tool first as it needed to be tapered and very tight.
