To get the support frame flat for the floor sheet was a real challenge because none of the mounting surfaces were in right angle. Therefore with the help of some rigging it was possible to glue the front and back angel into place. Later some time was used to cut the sheets to match the fuse sites. Only thing left was the middle support which needs to be removable for access.
