To fit the air intake scoop inside the fuse it was not easy at all, as the shape was not in line with the fuse intake. Therefore it had to be in an angle to the fuse to line up with the intake. Because of the gap between the fuse and the scoop I decided to cover the side with a sheet of fibre glass, which I had left from a cut-out of a model airplane cowl. The gap will be filled with a foam wedge later and fibre glassed around.
