Installed and manufactured the mounting bracket for the dashboard. A lot of measuring and trails were required to find the best medium to get the dash square into the fuse, have enough gap for the canopy seal and got it vertical as possible! Into the brackets were holes drilled to have more grip for the glue and the glass. Also I had to cut an angel to the top side of the sides to slide the frame out of the fuse away from the bracket.
