Glassed the fuse joint line with one layer 80oz glass stripe, this will avoid any hair cracks on the bottom after painting and will enforce the connection of the two fuse half’s. Beside there was quite a step (1mm) from one half to the other, which could be filled in and levelled out in one go.
