Drilled and cut holes for HS and Rudder, also prepared bearing seat for rudder hinges. Made a press seat for bearing, lock tide and pinned the bearing guess this will never move! Found also that the top bearing bracket angle was too steep touching the rudder hinge. Therefore I flocked a wedge under the top bracket to get it lined up correctly with the rudder.
