After adding the side cover on the seat and the back which I used just a black upholstery linen, i did the first trial in the air plane! and what a surprise as fitted as planned, first step was done so the second has to become as good as the first! The difficult part of this job is that the leather can’t be stretched and attached to a solid backing as the seat is only a foam cushion with a lot of curves!
