Preparing the air duct for the engine cooling, installed the mounting brackets as per manual and cut some templates for the front baffle. Currently couldn't install the alum tube for the ignition cooling because the ignition coil is not at the same place as in the manual. Contacted Jabiru for further advice to get it right!
