Garys RV-7 Builders Log
Date:  1-15-2013
Manual Reference:  8-9
Brief Description:  Drilled and mounted bottom of master cylinders.
Tonight, I aligned, drilled, and mounted the bottom of the master cylinders to the brake pedals. I think they turned out good and I am finally ready to mount the assembly in the fuselage.
Master cylinders installed.
Bottom of master cylinders.
End view of rudder/brake assy.
