Garys RV-7 Builders Log
Date:  1-13-2013
Number of Hours:  1.50
Manual Reference:  8-9
Brief Description:  Installed split collars, bushings and springs for
Today I installed the nylon bushings, springs, and set collars on the master cylinder shafts. I then used the belt sander to trim the rudder pedal tubes to the proper length. Next, I mounted the master cylinders and they are looking really good.
Next session, I will drill the holes in the pedal brackets to mount the bottom of the master cylinders.
Split collars, springs, and bushings.
Brake pedal assemblies so far.......
