Garys RV-7 Builders Log
Date:  6-24-2012
Number of Hours:  3.00
Manual Reference:  8-6
Brief Description:  Worked on seat rib top covers
Today I drilled the pan head screw holes in the seat skins to #19. I then dimpled and riveted K1100-08 nutplates that will secure the control stick boot covers. Next, I drilled out the rivets for the two seat ribs and made a doubler for each as recommended by Joe Blank at Van's. I match drilled, prepped, and primed the doublers. next session I can rivet and bolt the doublers and finally move on.
Nutplates for boot covers by larger square hole corners.
Drilled out rivets for seat rib.
Fabbed and primed rib doublers.
