Garys RV-7 Builders Log
Date:  6-16-2012
Number of Hours:  3.00
Manual Reference:  8-6
Brief Description:  Installed crotch strap brackets and seat ribs.
Today, I first riveted the crotch strap brackets to the seat ribs. I then clecoed all seat ribs in place and bolted them to the F-704 bulkhead. I torqued all nuts and applied orange torque seal.
It was at this point that I realized I had a misalignment issue with the bolt holes in two of the ribs. When I originally match drilled these two seat ribs I had them switched around from their proper location. The rivet holes line up perfectly, but the bolt holes are about half a hole off. My fix was to use a large diameter washer to increase the surface area against the flange. I will send pictures of the problem and my proposed fix to Van's to see what they think. This is a structural area and I want to make sure it will be fine.
Today my little girl turned twenty. Her dad is getting old.
Front view of crotch strap bracket.
Rib flange hole misalignment.
Possible hole misalignment fix.
