Garys RV-7 Builders Log
Date:  9-16-2007
Manual Reference:  6-5.9
Brief Description:  Started riveting the rear spar.
Today was Sunday and I spent some time working on riveting the rear spar to the VS. Mom read the paper and helped with some clecoes once in a while. I hand squeezed the rivets and they all turned out well except for a couple where the doubler and rivets wouldn't allow the yoke and bottom die to engage the shop end of the rivet enough. These may need to be drilled out, but I think a few blows with the rivet gun and bucking bar will fix them up. I ran out of time and will try that later.
VS rear spar clecoed in place to rivet.
VS rear spar in the process of being riveted.
