Garys RV-7 Builders Log
Date:  7-31-2007
Number of Hours:  1.00
Manual Reference:  6-3
Brief Description:  Pulled skin off skeleton and pulled off blue plast
This morning I used the angle drill attachment I picked up from Avery's booth at Oshkosh to drill out the previous drilled holes for the inboard rib to spar connections. This will be a handy tool for those hard to reach areas. Bob Avery told me it will be invaluable when I get to the wings.
The rest of the time I spent pulling off the protective blue covering from the skins. I used a soldering iron to cut a thin line in the plastic around the rivet holes. This allowed me to only remove the plastic in the rivet areas and leave the rest of the skin protected.
I now have a lot of deburring, dimpling, priming, and finally, riveting ahead of me. This will be the last time I pull this piece apart before it gets riveted for good.
Avery angle drill attachment for tight spots.
Pulled off blue plastic where rivets will go.
Skins and skeleton waiting to get deburred.
