While waiting for the new tip rib for the left side, I moved on to the right and I learned that sometimes it's best to just walk away from the project and start fresh. I had no issues with this tip rib, or riveting the skin to the front spar and the middle rib. It's a tight fit to hold the bucking back and then reach around the skin to hit the rivet with the gun. There are 98 rivets per side that need to be done in this way...I counted. The rest will be easily done with the squeezer. It's starting to look like airplane parts!
