Re assembled elevator and under structure to insure I matched drilled holes in E-713, E-704, E-713, and E-702.
Deburred and dimpled appropriate parts. I will prepare parts for cleaning and prime/sealing parts when the L Elevator is ready for this process.
Layed out holes for RH Static Wick’s. E-703 used as a dubbler for the outboard static wick. Inboard wicks use a fabricated dubbler illustrated below. This dubbler is made from 0.025 scrap sheet provided in the kit.
