Brief Description: Fitting Wing Walk Doubler & Skins
Cut wing walk doublers to size at Sarasota Avionics. I decided to leave the doubler its present width of 10” wide instead of cutting it down to 9 3/8”. Also, the manual states that the doubler extend “about an inch past the rear spar.”
The 26” length would just reach the rear of the rear spar web so I made the length approximately 27".
