MARTIN'S WEB SITE
RV-12 iS
N/A
Install K1100-8 Nut Plates in Horizontal Stabilize
Installed K1100-8 (2) Nut Plates on inside of HS Rear Spar HS-603PP. Drilled the hole in the middle of the inside HS-413PP Hinge Brackets for a #8 screw with a #21 Drill.
Nut Plate L HS
RV-12 Home
RV-12 iS Home
1354
728
Flight Controls
Fuel Tanks
Static Discharge Sys
523
