Brief Description: Riveting the Vertial Stabilizer
Finished riveting HS with exception of the rear spar. Will wait for the elevator to locate nut plates for the Static Discharge System.
Started to rivet the rear spar for the Vertical Stabilizer (VS). Realized that I did not dimple all the required holes, but was able to use the DRDT-1A Dimpling Tool to solve the problem
