Squared off the rough cuts at the top and bottom of the upper skin of the rudder and test fit that to the rudder spar mounted on the hinges attached to the fin spar. Made up the 0.040 doubler piece that sits between the rudder spar and the bottom rib of the rudder. this doubler also forms the support point for mounting the rudder control arm. Also cut out skin pieces for the bottom of the rudder on both sides. Also cut out raw aluminum blanks for the top, middle and bottom ribs for the rudder.
