Brief Description: fine tuning template for cowl openings
continuing to work on the template for cowl openings. So far it is looking like at east seven openings. That would be right side rocker arm covers, right side main cooling to cylinder barrels and heads, the crankshaft, left side main cooling to cylinder barrels and heads, left side rocker arm covers, induction air filter for carburetor, and one or more inlets for oil cooler supply. It's a lot to try to keep straight.
