Brief Description: forward fuselage to end of table, controls work
Moved the forward fuselage to the end of the table, and cleaned off the rest of the table in preparation for building up the aft fuselage. Set the main spar at the edge of the table and put some ballast weight in the seat pan so the firewall section won't tip it over. Worked on the bearings for the horizontal tube of the control system.
