Mark Weitkamp CX4
CX4
riveted right wingtip spar to right main spar
Clecoed the main spar and wingtip spar together, then clecoed the wingtip aft spar into place and attached the wingtip mid rib and wingtip tip rib.
using a steel T-setion to hold spars aligned while drilling and clecoing
begin framing up the right wingtip
need to hold wingtip rib level while fitting skins, trailing edge and leading edge.
CX4 Home
2592
Control system
cylinder baffling, p
223
engine cowling
86
365
fixtures and forms
390
paperwork for regist
Time spent on projec
814
