I fabricated two oil cooler angle brackets for the aft firewall. However, one of the brackets had to be modified due to the closeness of the bolt holes to the firewall vertical angle. Thus, I cut the right bracket thru the matched holes on the fabricated angles. To insure the backet would not be displaced I faricated another angle to lock the initial angle in place. This appears to work just fine.
