Brief Description: Began relocation of the battery box
The battery box has to be relocated since the oil cooler's best location is the right side of the firewall. To do this one rivet on the firewll forward cross support angle is removed and replaced with a AN-5A bolt that picks up the exisiting nutplate on the right side of the battery box. The other two nutplates will be used. I drilled two holes to capture these, plus fabricated a 1/8 x 1 inch thick aluminum angle to reinforce the firewall.
