Brief Description: Attaching HS-710/714 to HS-702 Front Spar
Finally received the HS-710 replacement from Vans. Trimmed it down, reamed the holes and bent the ears at 6 degrees. All the holes lined up correctly. Primed the splice and touched up the areas on the front spar. Riveted the HS-710 to the front spar.
