Brief Description: Front Spar Assembly - Drill HS-702/710/714
Drilled forward spar HS-702 and HS-710/HS-714 reinforcing bars. Instructions call out to drill all holes inside the bend line but DWG 3 excludes 4 holes. Checked with VAF forums and builders say to not drill those holes. They will be drilled later as per the drawing when attaching to the fuselage.
