Brief Description: Smoothing HS-609 PP to a satin like finish
Scotchbriting the HS-609PP to remove scratches. A lot of small scratches. Half way down the side of one 609 a lot of scratches had be removed. At first a Scotchbrite pad was used to smooth the face of the 609 to a satin like finish. Way to much effort for little gain. This is where the Scotchbrite wheel knocked out the job in short order.
The nitril or latex gloves helped to keep the finger prints from starting the corrosion process.
