Brief Description: Fabricate and install Fuel Tank Shut Off
Installed mesh fuel screen, fuel shut off valve, and shut off control rod that I fabricated. Used 2 pieces of light aluminum angle(.075 thick) and 2 AN bolts for framework.
Side view
Control rod is 3/16 OD X.35 tube
Control rod can pivot on AN bolt that is attached to valve handle
