Swapped the ammeter leads on the shunt so that current flow from the alternator will be shown as positive rather than negative.
Removed the thottle linkage bolt from the fuel servo lever to determine how to increase the amount of throw at the servo. I plan to call Avstar to see if they have shorter levers available.
Reinstalled the wing root fairings on the LH wing.
Update 11/22/21: Called Avstar and ordered a shorter throttle lever that should work.
