Added fuel to the RH tank for the first time. Followed the same fill/drain process that I used on the LH tank to flush out debris
Removed the boost pump and bench tested it with no success. It still just clicks when power is applied.
My wife embroidered my plane's N number on the front of a document pouch that I bought to hold the W&B report and other papers that will be carried in the airplane. Looks good.
11/8 - Contacted Airflow Performance who said it sounds like the test fluid has congealed since it’s been sitting for so long. I sent it to them today to have it looked at.
