N983LK
RV-8
Prep for flight
10-29-2021
Prep for weighing
Torqued the landing gear bolts
Lifted the fuselage and removed the sawhorse from under the spar carry though. Lowered the fuselage to put it back on the main gear
Installed the wheel pants, upper intersection farings and lower cowl.
Sanded the epoxy/flox on the aft edge of the RH wing tip. Applied epoxy/micro to the area.
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
