Brief Description: Started snorkel fit up and cowl part 9
Fabricated a tool to bolt to the front of the fuel servo which will position the servo end of the snorkel an line it up concentricly with the fuel servo inlet. Bolted it in place on the servo with double back tape between it and the servo. Removed bolts and installed zip ties in the holes (The bolt heads would not allow the flange of the snorkel to fully seat on the servo)
Cut the two forward lugs off of the starter to allow clearance from the snorkel. This is allowed per the Skytec starter drawing
