N983LK
RV-8
Baffles
1-13-2021
Baffles part 5
Cut the oil cooler opening in the left hand rear baffle. Installed the baffle on the engine.
Temp installed the 90 deg fittings in the oil cooler and clamped the cooler to the baffle.
Hooked up the oil lines to the oil cooler to assess the routing.
Cutting opening for the oil cooler
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
