N983LK
Date:  4-22-2018
Number of Hours:  4.00
Brief Description:  Underfloor wiring RH side
Fabricated a bracket for the CPC connector for the roll servo wiring from the RH wing. Drilled holes to mount it to the RH fuselage wall in the underfloor.
Installed a ground wire solder sleeve on the end of a length of 3 conductor shielded cable. Drilled a 1/2" hole in the RH underfloor fuselage side wall and installed a snap bushing. Routed the 3 conductor wire through the snap bushing (this wire will be for the RH nav/strobe. Drilled a hole for an Adel clamp to hold the 3 conductor shielded cable. Terminated the wires in the 3- conductor shielded cable with ring terminals and attached them to the nav/strobe terminal block.
