N983LK
Date:  4-3-2021
Number of Hours:  6.00
Brief Description:  Prop oil line and Baffles part 8
Finally received the prop oil line that had been backordered from AC Spruce and trial fit it on the engine. It took me a little while to figure out how to route it but once I figured it out it fit well. I had to remove the fuel flow sensor-to-fuel distributor fuel line and the oil line needed a little bending at the front but I got it connected and it fits well. I took it back off and will re install it after I fit the RH inlet baffle for the final time since the oil line runs through a hole in the baffle.
For the rest of the work session I worked on fitting the RH inlet baffle which consisted of multiple iteration of installing/removing the baffle and lower cowl and bending and trimming the inlet baffle and cylinder #2 baffle.
Prop oil line at governor
Prop oil line routing
