N983LK
Date:  7-6-2020
Brief Description:  Control cables
Sanded the flox on the wing tips in the unused nut plate locations and applied a layer of micro
Removed the throttle quadrant. Routed the throttle, mixture and prop cables from FWF to the throttle quadrant. Ordered hardware from ACS that is needed to attach cables to throttle quadrant.
Installed one of the cable pass-through eyeball fittings to check the fit.
