N983LK
Date:  7-25-2020
Number of Hours:  4.50
Brief Description:  Canopy skirt - shortening the aft edge
Did a little clean up (filing, sanding) of the wing tips and applied some more spot putty in a few places.
Trimmed about an inch off of the aft end of the canopy skirt to allow the canopy to open further to give the backseater more room to get in. Sanded and filed down the aft end to thin out the trailing edge and form the channel shape around the canopy rail.
Applied epoxy/micro on the bottom of the aft end of the canopy skirt and clecoed the skirt on the canopy frame/bubble so that the epoxy will cure and fill the gap between the skirt and the fuselage.
Copyright © 2001-2021 Matronics. All Rights Reserved.
